Originally Posted by euromodder
NOx is far worse than a slight decrease in FE.
Have you forgotten about the acid rain, dead trees, or have you never seen them ?
Despite EGR, we still get better FE than maybe 95% of the US ...
Well, people sometimes forget that if you increase your mileage because of it then you total emissions per mile is lower, i.e. NET lower emissions. It all varies depends on speed/load, but your net emissions will most likey be higher w/o EGR, even with increased mileage.
back to the car in question, PIWOSLAWany update on coolant temp with the adjustable grille block?
