Dropped the 195/65-15 mules off to be mounted today, but I didn't get back to pick them up before the shop closed. I won't be able to do testing until mid-June. I propose ABCA cruise control and P&G testing over the same 10 mile course. To minimize the number of mountings/dismountings, the three different-sized front pairs will all drag the same 205/50-17 rears, and I plan to run them like this:
205/50-17 cruise control 33 mph
205/50-17 P&G 25-40 mph
195/65-15 cruise control 33 mph
195/65-15 P&G 25-40 mph
185/60-15 cruise control 33 mph
185/60-15 P&G 25-40 mph
All cruise control tests will run at actual speeds as indicated by my Garmin Nuvi GPS.
P&G tests will run 1500-2500 rpm in 4th gear at roughly 78-83 load, with EOC.
I know the stock 185/60-15 tires use a 1.033 distance calibration (10 miles on the odometer is 10.33 miles actually traveled), and the new 205/50-17s use a 1.099 distance calibration. I'll establish the distance calibration for the 195/65-15 mules before testing.
I will inflate all tires to maximum sidewall (cold) pressure.
I will record temperature, weather, wind, and road conditions. The test road has little traffic, and I will run it on a weekend to avoid interference.
I have weighed the stock wheel/tire (185/60-15) combo at 35.3 lbs, and the 205/50-17 replacement combo at 47.3 lbs. I'll weigh the 195/65-15 mules when I pick them up. I'm assuming they'll weigh about 37.5 lbs.
Now is your chance to propose any changes, and to question my methodology. Any and all comments are appreciated.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
