Old 06-03-2011, 08:13 AM   #20 (permalink)
KamperBob
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by Diesel_Dave View Post
JR, I like your cap. It looks really sharp! No offense to some of the others who have put together aero-caps, but I want something that doesn't look like some garbage duct taped together.
What type of epoxy did you use? Did you use 1 or 2 layers of 1/4" plywood?
Originally Posted by JRMichler View Post
The top is two layers of underlayment luaun (sp?) plywood nominally 1/4" thick, but actually 3/16" thick, so the total thickness is 3/8". The sides are one layer of that plywood because the spans are shorter. Years ago I built a topper with one layer of 1/4" fir plywood. That one sagged between the ribs after a year or two.
All joints were glued with Titebond II or III or whatever. It's the latest and greatest Titebond.
After sanding and filling defects with Bondo, I sealed with one coat of West System epoxy. I buy it in the gallon resin / quart hardener size and leave the pumps on the cans. I use the 206 slow hardener. I've been buying it from Aircraft Spruce.
Sand off the high spots, spray on some sandable primer, use up a whole tube of spot glaze, finish the second spray can of sandable primer, and brush on gloss enamel from the local hardware store. Wet sand the enamel, brush on another coat, repeat until sick of painting, put on truck. Done.
I agree - looks nice. Linking pix here for convenience.
Short of your own thread it would be good to know about how much it weighs. Also what MPG difference with versus without the cap.
Recreation Engineer
