Old 06-03-2011, 11:32 PM   #43 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
The mules' sidewall pressure will determine what I'll use, since the stockers are 44 psi and the newbies are 51 psi. The mules will make 2 of 3, so I'll change the pressure of the odd man out.
At 4 a.m., it's dark enough that I'd need to run lights, which would introduce another variable. I don't think I'll bother running on the C tires to the starting point, as I doubt it will be worth my time to swap tires for a 4 mile drive, when it's questionable whether the tires will even warm up. I will read inflation pressure and tire surface temperature (with an IR temperature) when I leave home, when I start each test, and when I end each test.
Starting the first A test with cold engine and bearings is going to mess me up, since all the other tests will have a warm engine and bearings. I think I'll run two A tests right off, to get the engine and bearings warmed up. Unfortunately, that's going to warm the tires up. I can't win for losing.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
