Old 06-05-2011, 11:12 PM   #55 (permalink)
Pendragon
Is there anything behind the upper grill opening? (I don't recall when it was that Honda changed things to being a "bottom breather", but had to add the upper grill back because of customer demand (because of appearance). Do keep a close eye on temps when doing this tough as you may have to have different parts for the hot and cold weather.
There was a comment early in the thread about gasoline & mileage. The gas in California is very different, even from one part of the state to the other a well as depending upon the season...and then there is that *%#&! ethanol which gives poorer mileage, is damaging to some engines, takes more energy to produce than you get out of it and is a political boondoggle. Grrr!
