this is what i use, makes relatively quick work of filling the tires, though it will blow the fuse if i run it for more than about 10 minutes.(only happened once, when topping off my tires as well as the tires on my buddies Jeep.)
Amazon.com: Slime COMP03 12-Volt Air Compressor with Gauge and Light (300 PSI): Automotive
