06-05-2011, 11:32 PM
#11 (permalink)
Is there perhaps a quality foot pump with a gauge in it that could be kept in the trunk to keep tires topped up nice?
I'd be willing to pay 30-50 bucks for something that I knew would last and keep me from having to run around trying to find free air.
06-05-2011, 11:38 PM
#12 (permalink)
Making Ecomods a G thing
I have a Slime Brand compressor with a built in gauge, though don't know how accurate it is, hence why I have 2 separate gauges to check pressure
06-05-2011, 11:45 PM
#13 (permalink)
If you want accurate, get a good dial gauge and thread a tire chuck to it.
Most if the ones smaller than 2" are junk.
If it has a calibration/zeroing screw it is probably a good one.
It will set you back $20 but I have ones older than me that still checkout with >$100 NIST traceable ones.
When you think about how many $4 Discount Auto ones have died on you, $20-30 doesn't seem so bad........
06-06-2011, 12:20 AM
#14 (permalink)
...beats walking...
Originally Posted by Bill in Houston
Any tips on where to find a calibrated source?
...I go to my local tire dealer and compare my el-cheap-o gauge with the one *they* use to check TRUCK tries with, which THEY check against their calibrated compressor gauge (an Ashcroft(?), I think).
06-06-2011, 02:10 AM
#17 (permalink)
I've got one of the digital gauges that reads the pressure to the nearest 1/2 pound. It gives consistent readings, I've never checked it against a calibrated gauge, but does seem to be much more accurate and consistent than any of the pen type gauges I've used. Sorry I can't remember what brand it is, but remember it was a brand that I trusted. I think I paid about $8. for it. Many of the pen type gauges I've tried will give me one reading one time then without adjusting the pressure get a completely different reading (sometimes several psi) 10 seconds later.
06-06-2011, 02:15 AM
#18 (permalink)
Originally Posted by Joenavy85
I've never used the Slime brand portable compressor, but I've used other brands. I used to have two different ones and the gauge readings between the two varied by about 10 psi. I guess the main thing is using the same one for all tires and having them all at approximately the same psi.
06-06-2011, 10:34 AM
#19 (permalink)
EcoModding Alien Observer
I've had 3 12V compressors over time and the last one I bought was this one...
Ryobi 12-Volt Inflator/Deflator with Flashlight - YN600A at The Home Depot
Good price and has the light and an auto shutoff feature...also puts out more air than some of them. Places to store the cords too.
Air gauge is not accurate...will need a verified handheld gauge.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
06-06-2011, 11:50 AM
#20 (permalink)
Interesting. Thanks.
