Old 06-06-2011, 11:35 AM   #8 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by groar View Post
I never rev matched on any car I drove, gasoline or diesel, and never heard about it before reading hypermiling forums.
I've been doing that since I learned to drive in the late 1980s.
You're doing it when shifting up, but probably don't realize it
Is it how old cars (older than late 70's) had to be driven or is it an hypermiling trick ?
It uses gas, so it's not really a hypermiling trick.
It keeps you from slowing down much though, if you just want to get into a lower gear.
It also reduces wear on the clutch plates, as you reduce their relative speeds when coupling them.
