It's software rev 1.11b I think. Yeah, when you put a value in the precharge timer it flashes the yellow light and indicated on explorere when the precharge timer is timing. Pretty neat.
Originally Posted by Nevyn
I think some of this is built into the new board that Paul has. Am I right on that, Paul?
badfish, for as long ago as you say you built it, you probably don't have the "new board."
Guess the easiest would be just to precharge and apply 12V to the controller at the same time. When the controller times out, close the main contactor.
I just remember reading a story about the controller going full PWM when the power wasn't applied(trying to develop desired current), then when the power finally came on, it was full power at a standstill.
Thanks all.
