Old 06-07-2011, 11:40 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by vijay View Post
Thanks. Currently the rpm drops to 1000 after upshifting. I will increase to 1.5K's and check for juddering. In P&G once the desire speed is reached do I need to put in neutral and coast or simply pull off the accelerator then apply 50~75% throttle.
Put the clutch in and glide. If conditions are safe enough, cut the injectors and leave the ignition in the run position. Bump start in fifth gear--even down to 15 or 20 mph.
