Old 06-10-2011, 12:49 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
The Civic Hybrid has 15" wheels I believe and a pretty good aero wheel surface. You need Low Rolling Resistance tires too. The size of the tire can make a difference in addition to the wheel. You might save the cash on the new wheels and look into larger tire sizes that fit your current wheels. Save $$$. Also, the overall diameter of the tire/wheel is inversely proportional to the RPMs rate. The power wheel/tire is basically a gear. You also want to take into account increased rotational mass from a heavier tire/wheel combo. See Sentra_SE's current discussion about switching to larger tires. He is having interesting results.
larrybuck (06-10-2011)
