Old 06-12-2011, 09:43 PM   #1 (permalink)
newguyintown
Using components in a gas generator as a motor?
Is it possible? It seems like if the generator can make x kilowatts of power that you could use the electric motor(it would have to be a brushless motor to make the power right?) as a motor. Would this be possible? I've seen fairly cheap generators that have 5kw or capacity and I was wondering if it would be possible to get out the motor and use it as a 5kw motor.
