Old 06-14-2011, 01:29 AM   #6 (permalink)
backyard engineer
did away with my antenna also (love my IPOD) no speakers, no radio. covering the hole was quick temporary. I fully intend to redo it. but I wanted to share using vinly graphic material. it bonds excellently yet is still easily removed in case you want or need to redo it You can get this stuff in 9x11 sheets at craft stores like Michaels available in several basic colors for like 3 bucks. the blue left over from older project. this stuff also makes a good waterproof seal. also might want to check with your local graphics place for scraps or a better color selection. you might notice I put a thin adhesive aluminum label under the graphic material for strenght and rigitity over the sort of large hole. also did this type covering on my crx rear wiper delete(similar large type hole)
The Following User Says Thank You to backyard engineer For This Useful Post:
California98Civic (06-14-2011)
