I have removed both side mirrors and covered the factory mount area with ABS plates. Tape is from install using construction adhesive as well as rtv sealant for a real nice fit and finish. convex mirror is now inside(was mounted outside previously).After checking south carolina laws seem the only requirement is to be able to see 200ft behind the vehicle.I'm pretty sure I found that info here on EM if one of you guys would maybe be so kind as note where that info can be found so any other interested viewers could find it
also included photo of passenger side plate tanning on the back deck in the hot south carolina sun prior to its install
