Old 06-15-2011, 11:04 PM   #233 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
The cycle is now SHOW-READY!
Does that mean it is totally done? Heck no. I still have to do the headlight/tail-lights/horn/turn-signals wire harness and the DC/DC converter to power it.
But nobody looking at the cycle at the energy fair needs to know that!
Anyways, here's what I did today...
Had to take out the top batteries to get the middle section of battery rack out. I had to take that out because yesterday I managed to pop a weld. I snapped off the little ring of pipe that holds the middle rack to the lower battery and the frame.
I reground it, re-welded it, painted..... Waited for hours for paint to dry, then put it all back together.
At least I had other things to do while the paint was drying.
Since I had the middle rack out anyways, somebody mentioned to weld my two stacks of three washers to make spacers. I finally did that!
See! Washers, now welded together!
I also did not yet have the return spring for the rear brake. It turns out that the spring hooks onto a peg that's on the MUFFLER! Well, there's no muffler anymore, so it's time to FABRICATE something!
The muffler would have mounted below the right passenger foot peg, so I made a small metal plate with two holes, one for the foot peg bolt, and one for a 1/4-20 bolt for the spring to hook on. I put the small bolt through, welded it, then ground off the head (It wouldn't have fit otherwise.)
After that, it was time to work on the chain guard. I found a hunk of aluminum computer rack server rail. It was about the right thickness for a big spacer between the motor mount plate and the side of the cycle. I cut it 9" long and ran it vertically. Here, you see it left of the motor.
I then went to work trimming some salvaged plexiglass to the right size, with cut-outs to go around the bolt-holes and odd shapes on the right. The server rack material featured threaded holes, so I just found the right size screws and drilled a couple matching holes through the plexiglass.
I also cut a narrower piece of plexi for the top. I am still not sure of the best way to attach it. Right after I took the following photo, I just ran a piece of electrical tape over the corner of the two pieces. It actually looked pretty good... I might just use some clear silicon or something to finish that corner.
I don't know if it comes through in the photo or not, but it looks like the chain and sprocket are in an aquarium.
Here's the cycle again, once I finally got it back together (but before I got my tools put away!)
Here's the other view, with horrible orange background lighting.
Here's where I will be for the next four days! Hope you can make it too! Look for me, I'll be the guy by the motorcycle in the "Open ReVolt" shirt
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following User Says Thank You to bennelson For This Useful Post:
Christ (06-16-2011)
