Old 06-17-2011, 11:30 PM   #6 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Diesel. A mechanical injection diesel will be a really easy swap, you just have to male an engine mount and adapter plate.
If you use a vw engine, you need a rwd/scirocco clutch set/flywheel, and you stick the civic friction disc between them.
