Old 06-19-2011, 07:46 AM   #137 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Al got the illustrations scanned for the gap-filler side panels.
They're a 'solution',not 'the' solution.More later.
Looks complicated.
How about a rounded-off front, and spring loaded side panels ?
A small wheel on the inside of side panel can roll on the trailer's front - maybe on a reinforced patch of skin.
A castor wheel will allow for horizontal and vertical displacement of the trailer.
A simple physical blockage can prevent the side panel from retracting too far inboard (due to the spring) when the gap widens on that side.
Instead of using a wheel, a half-sphere of Teflon would easily slide over a strip of Teflon on the trailer.
