Originally Posted by JeepNmpg2
It is nice to only have the very bottom of the front differential and the lower portion of the control arm exposed. The lower edge sits about .75 of an inch lower than the axle.
you could probably make a small lip to go on the trailing edge of the pan without too much difficulty, that would deflect the air under the Front Diff, though the control arms would be more difficult
