Old 08-04-2010, 10:40 PM   #31 (permalink)
Since you have a Scangauge, just use it to calculate mpg. I think those fillup numbers are way too small to get anything meaningful out of them.
Old 12-15-2010, 12:11 AM   #32 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Jeep Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Kia Sedona LX
- Update -
I haven't been on here in a while, had some personal emergencies come up, and moved, blah blah blah...
I hate to say it, but in my earlier testing I think my foot was still a little biased and the track was too short. I did drive with it on for a couple of longer trips (80 miles each way) and now I think the mileage increase is more around the 2%, rather than %8 or so.
Even worse, is somehow it got hit while my car was parked back in October and subsequentially tossed (although I did take it to get recycled as it's all plastic) as it was beyond repair. While I didn't get my money's worth in the investment, it was nice to build such a concept piece and try it out. I might make another in the future now that I've learned some lessons and from my early mistakes. I think I'm going to stick to cleaning up my undercarriage first before I go and mod the rear end (again).
Old 12-15-2010, 01:16 AM   #33 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Sorry to hear about the Kamm Hopefully version #2 will be even better, and cleaning the flow under the car will also help the new Kamm. Good luck
Old 12-16-2010, 06:46 PM   #34 (permalink)
Get a full width skid plate, then build off of that.
Old 12-16-2010, 07:51 PM   #35 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Skidplate
I'm looking at this one from DPG Offroad - either that or I'll get a local shop to bend one for me based on these pictures and some custom measurements.
From the side:
From the back:
Instaling the plate won't be all that hard; building around the driveshaft, springs and axles will be the tough part. Not to mention insulating the area around the exhaust. Maybe I'll get lucky and find some place that has recycled street signs like I saw on a post here with a Subaru STi. I'll open another build thread when I do get to that point.
Old 12-18-2010, 01:03 AM   #36 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
updates! we need updates! we care!
Old 06-17-2011, 12:18 PM   #37 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Updates
Moved to GA for some job training, but last weekend I starting fabricating a front air dam to push the airflow under my front suspension out of black coroplast, aluminum angle stock and rivets. Pictures to follow later on today of where I'm at on it. Here is my shopping list so far:
$14 - (1) 4x8 sheet coroplast
$8 - (2) 16GA aluminum angle 8 ft stock
$4 - (2) 3/16 aluminum rivets 50 pack
$2 - (1) small angle bracket pack
$3 - (1) small 90 degree joice pack
The prices are each so the total investment is $43.
FastPlastic: I wish I had your skills with sheet metal, but I'm going to have to live with my beating/hacking on coroplast for this one.
Old 06-18-2011, 07:18 AM   #38 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Clean up the front end
Well, my plan was to finish the pics last night, but I got distracted as always.
The first pic is just the naked front end, but you'll notice that since I don't have a stock front end anymore (below, courtesy of FastPlastic), I lack the air dam that kept most of the air out of my suspension.
so this is my remedy for that. It's actually a square sheet, but the picture makes it look odd. Also it should be noted that it will clear my tires at full turn by about 2 inches
As far as attachment points, in the front I plan to tie into the built in ones behind the bumper face (normally where you would relocate the vacuum ball from the stock setup). As far as the rear end goes, I will either drill and make a bracket on the front end of the lower control arm mounts and allow it to self-adjust based on suspension travel. Or else I may have to hang the piece off of the framerail before the suspension and find another way to support it.
Name:	Jeep Front Before.jpg
ID:	8738   Click image for larger version
Name:	Jeep Front Drawing.jpg
ID:	8739   Click image for larger version
Old 06-18-2011, 01:11 PM   #39 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Looks good I don't remember if I really showed it but my panel actually gets smaller the father back it goes(Kind of a V shape), gave me more surface area in the front that way. I also found on the frame is a threaded hole, after a few quick test bolts I found the one that fits. here's the bracket I made, but I would recommend a little beefer one if go this route as mine is all bent out of shape and needs to be redone(plowed too many snow drifts).
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 06-18-2011, 04:08 PM   #40 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Cool Cherokee Air Dam Installation
Down to business
Here's the bracket I made using an existing hole in the body:
Both brackets in a frontal view:
Here's a shot of the top of the pan:
*The larger hole on the right hand side, that is so that I can still access the winch clutch.
Partially hung dam, still mocking up the side panels:
Completed side panel:
*There were small spaces in the back of the bumper to fit those 'tabs' into, almost like it was a part of the design!
Everything buttoned up on the ground:
I thought I was going to sweat to death getting this thing together, but it all worked out. Overall I'm absolutely pleased and cannot wait to see where this puts my highway mileage. I've only taken it up to 75 MPH for about ten miles to feel for any shimy and check to ensure it's safe to operate the vehicle. I will say that the Jeep seems to coast A LOT further when I NC (Neutral Coast). I'd love to do some A-B-A Testing with it, but it's a total PITA to put on and I'll assume take off. It is nice to only have the very bottom of the front differential and the lower portion of the control arm exposed. The lower edge sits about .75 of an inch lower than the axle.
Name:	Jeep Air Dam 1.jpg
ID:	8744   Click image for larger version
Name:	Jeep Air Dam 2.jpg
ID:	8745   Click image for larger version
Name:	Jeep Air Dam 3.jpg
ID:	8746   Click image for larger version
Name:	Jeep Air Dam 4.jpg
ID:	8747   Click image for larger version
Name:	Jeep Air Dam 5.jpg
Name:	Jeep Air Dam 6.jpg
ID:	8749   Click image for larger version
Name:	Jeep Air Dam 7.jpg
ID:	8750   Click image for larger version
Name:	Jeep Air Dam 8.jpg
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 04:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
