Old 06-20-2011, 04:50 PM   #62 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by SentraSE-R View Post
Thanks for your suggestion, CarlosSW. Tire sizes incorporated in results summary.
What a great suggestion Carlos gave. Thanks for adding it that way. It suggests that taller is not better if it means significantly heavier, but that weights being relatively equal taller is quite a bit better than OEM. Given my plan to go taller on the fronts and create a net loss in weight by balancing it with smaller rear tires--all on the stock 15" wheels--this is really encouraging data. Much obliged. Model test. I'll have to consult this again next time I'm testing. You do these well.
