Old 06-21-2011, 10:12 PM   #2 (permalink)
Tango Charlie
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Looks sweeeeet.
You might want to consider blocking the upper grille opening, and partially blocking the lower opening. The upper opening is typically a styling point, and the lower opening does most of the work. Do you have a Scangauge or Ultragauge? If you do, you can keep an eye on coolant temperature as you progressively block the openings. Don't trust the stock gauge that's in the dashboard; they're notoriously innacurate.
Good luck!
-Terry
