Thread: HI
Old 06-22-2011, 01:46 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mike1611 View Post
also, I would like to hear any other suggestions to boost MPG. my job demands a whole lotta city driving, so any little bit helps.
Daox has a great suggestion re: the VX. But if the HF engine is compatible with your generation civic then you might do that too. You might consider simply a transmission swap instead of the whole engine. Seems much of the FE benefits for these guys is in the gearing.
As for driving tips, consult the 100+ hypermiling tips in the links above. Do whatever appeals to you. Experiment.
Start a fuel economy log here on the site. You'll get a good record of a baseline before you start modding, and you'll be able to track improvements.
Good luck!
mike1611 (06-22-2011)
