Old 06-22-2011, 05:36 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
If gas is 8lbs/USgallon and you are buying an extra 14 gallons more than you might (to fill the tank) then you are talking an extra 132 lbs. If every 100lbs can mean a 2% change in FE... there you go. Not tremendous but maybe not insignificant, depending on your car's base mpgs. I fill the tank all the way. I ran it down brutally low last time and saw pumping problems. Never again.
