Old 06-24-2011, 12:46 PM   #200 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Biodiesel oil dillution
Originally Posted by euromodder View Post
The biodiesel content in our regular diesel makes it even worse, as biodiesel doesn't burn as easily, so it gets into the oil more easily than regular diesel.
Actually, the issue isn't that biodiesel doesn't BURN as easily. The issue is that biodiesel doesn't EVAPORATE as easily. You get more or less the same amount of oil INTO the oil. The issue is that quite a bit of conventional diesel will evanporate out on it's own, biodiesel won't go OUT of the oil.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
