Old 06-16-2011, 07:36 PM   #191 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Piwoslaw View Post
Well those pictures reveal the problem: The S40's roof is more or less parallel to the airflow lines, but the V50's roof is perpendicular to them!!
LOL
There is also the possibility that whatever you are using to see FE is miscalibrated.
Sure, but there are other signs as well.
The fuel level meter works independent from the OBC.
Tank size is identical, but the needle is dropping slower than on my V50.
I got an extra 50-70 km before hitting the first 1/8 marker.
On CC, the fuel consumption doesn't shoot up as fast on an incline, and it doesn't get as high. Killing the CC uphill, it also responds far better to manual throttle application. Speed hardly drops, while FC remains constant on inclines where my V50 would either loose speed or increase FC.
The average is at 3.9 L/100km or 60mpg.
@ 100kph on the motorway, it's often indicating 75+ mpg
Estimated remaining range and distance driven combined, have indicated over 1600km / 1000 miles.
The Scan Gauge may need a few tanks in the S40 to get used to it, while the onboard computers are far from accurate.
On my diesel, I feel the SG gets calibrated to my driving style, not to the car.
So I don't really use the scangauge to keep track of fuel economy.
The funny part:
The oil level on the replacement car is as high as on mine.
It already went through 2 DPF cycles, only 200km apart.
I only noticed them because I saw the intake temp increase on the SG.
On my V50 the process usually starts with a small jerk, just enough to notice something's up.
So either both cars have the same issues or these Volvo's can't take mild hypermiling.
Old 06-17-2011, 09:12 AM   #192 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Arragonis View Post
Maybe its better run-in than yours. Start a second career minicabbing with a partner (24 hour cover than way, it will never get cold) for a couple of months and then at maybe 300k km it will feel just as loose
Heh! When I worked at europcar (VW'S Car hire place), We uses to ensure each new car to the fleet recieved an "Italian Tuning" on the way to the car park- they were much faster after that.
Seriously though, regarding the s50 being so much better than the v50- it sounds extreme, but a back to back rolling road test may indicate differences?
Sounds like your car feels "lethargic" in comparison?
Could the injectors be clogged?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 06-17-2011, 10:05 AM   #193 (permalink)
The PRC.
Mrs A was interested in a Pug 406 Coupe a few years ago, in Mint Green only. A HDi one came up at the local Arnold Clark (Seafield if you know it).
We went to have a look and as we did and the sales guy was going on about its condition, their warranty and how they take care of customers, a mechanic reversed a newly serviced 206 out of the bay doing over 30 going backwards, flicked it round on the handbrake and skid-parked in the "Service Only" spaces.
He then clanged the door on the car next to it as he got out and jogged back in whistling.
The salesman looked at us and said "I suppose you don't want it now ?"
Yup.
Old 06-17-2011, 08:27 PM   #194 (permalink)
euromodder's Avatar
As it's a loaner, I can't compare them at the same time.
Lethargic is way exaggerated, but the difference could be felt switching from the V50 to the S40.
Having driven my V50 from new, it doesn't feel wrong though.
By comparison, my own car drives better when cold.
Is there a way these could be checked remotely ?
Physically checking them is out of the question.
It was 400 euro in labor alone to clean off the crud and replace a blown seal on 1, so I would rather not go there.
Old 06-18-2011, 03:58 PM   #195 (permalink)
Team m8
Get them to pay for the RR session- after all, its them that have failed to fix the issues so far!
Old 06-23-2011, 12:06 PM   #196 (permalink)
The PRC.
I found this just now, checking out Vauxhalls for someone.
With the 1.3CDTI (FIAT 1.25 Multijet) engine fitted with a diesel particulate filter, what can happen is that excess diesel fuel that was supposed to burn hotter and regenerate the dpf does not and instead seeps into the sump, gradually raising the level of sump oil to the point that the engine starts to run on it, cannot be stopped and therefore self-destructs. Vital to check sump oil level regularly.
Different engine, same problem though ?
Old 06-23-2011, 06:29 PM   #197 (permalink)
euromodder's Avatar
Yes, that's the oil-dilution issue.
The biodiesel content in our regular diesel makes it even worse, as biodiesel doesn't burn as easily, so it gets into the oil more easily than regular diesel.
With the very frequent regenerations, oil dilution really becomes an issue.
That's why I want them to find the root cause.
Coming home from work, I couldn't resist filling up Snert, the replacement S40.
4.08 L/100km or 24.5 km/liter
57.66 mpg (US)
69.24 mpg (UK)
Instant Hypermiler status !
Old 06-24-2011, 04:55 AM   #198 (permalink)
The PRC.
I wonder how common this is, still considering a non-diesel swap. But then again I like the oomph from the turbo.
Old 06-24-2011, 06:30 AM   #199 (permalink)
euromodder's Avatar
I'm afraid it's very widespread.
Old 06-24-2011, 12:46 PM   #200 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Biodiesel oil dillution
Actually, the issue isn't that biodiesel doesn't BURN as easily. The issue is that biodiesel doesn't EVAPORATE as easily. You get more or less the same amount of oil INTO the oil. The issue is that quite a bit of conventional diesel will evanporate out on it's own, biodiesel won't go OUT of the oil.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Cordless Electric Lawn Mowers Do Work! rgathright Saving@Home 21 12-09-2011 11:08 AM
From 15 to 23.75mpg in a 5500lb work truck JacobAziza EcoModding Central 21 12-04-2009 02:38 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 12:45 PM
Scangauge doesn't work lovemysan Instrumentation 2 09-01-2008 11:49 PM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 11:03 PM
