Old 06-25-2011, 01:14 PM   #7 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I made one a year or two ago. I used some stainless wire safety wire that I had around and tensioned it with a door spring for the same reason as you mentioned. My spring is about 3/4" diameter and 6" long. I powered about 26-28" of wire.
I used a board with end boards to space the wire off the neck board.
I powered it with a 12v 6a battery charger after testing it on the 2a setting first.
Of course the wire stretches because it gets hot. If I went too fast it would still bow some.
Noah Webster, 1787
