jamesqf, thanks for that. I did notice the periodic drop out of lean burn (when load was otherwise constant) and wondered if it was the NOx purge.
As for the mild engine stumbling, I believe when the IMA system is enabled, it may help to smooth over this. Will test to confirm. I will also check other tune-up items - e.g. I wonder if the local dealership installed the indexed spark plugs properly (have my doubts).
Originally Posted by California98Civic
Welcome back. Have been reading your Metro site. The pic of the Kamm makes the Kamm look professionally made.
Thanks! I wish the
finish looked as good - it's peeling/flaking in several spots now. Detail work, I'm not so good at!
