Hi OB,
Maybe a simpler method. Click on your picture so it shows full size - like
this link.
Then right-click on the image and select "Copy Image Location" from the menu if you are using Firefox. If you are using Internet Explorer you have to right-click and select properties. Then in the window that appears about halfway down is an entry called Address (URL). Right click on that and choose "Select All" and then right click again on the highlighted part and select "Copy" from the menu, and then OK.
Why oh why does IE make this harder, no idea. Install Firefox
Then in your reply type
"[IMG]" (without the "s)
Then press Ctrl + V to paste the location copied.
Then afterwards type "[/IMG]"
The result looks like :
[IMG*]http://ecomodder.com/forum/member-oldbeaver-albums-pictures-skoda-octavia-1-9-tdi-picture2984-skodagrillcover.jpg[/IMG*]
(ignore the *s - I had to add those so you could see the text) - Click on Preview and image comes out :
Your Octavia is exactly like the Mrs A-mobile but a different colour, I assume since you tapped its the 1.9 it has the 105 engine, which is very good for FE - my dad had one and got 60MPG (imp) without really trying. he has a 1.6 CR one now and claims 70.
And that grill block is very very tidy. Do you / would you consider making a template if I end up keeping Mrs A's car when the Prius arrives ? What is holding the rear of the screws and what is the material ?
