I do not know what you added but I assume that you changed one or all of the following injectors, Fuel pressure regulator, and fuel pump. By changing the injectors you might have a better spray pattern and atomization allowing for the fuel to more easily burn completely. The last two can increase fuel pressure and the amount of fuel the injectors can push, the effect is similar to replacing the injectors.
Other wise it could just be in your mind and the change in weather.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
