Old 06-29-2011, 02:26 PM   #98 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Clean grounds do create less load on the engine, as well as cleaner signals and faster response time from the ecu.
Think of it from the perspective of current: easier to walk in water, or syrup? It takes more energy to walk in some substance that doesn't allow free movement, and it takes more energy to transfer current through a corroded write not making good contact.
This is actually something you might remember me suggesting occasionally as a good thingto check on a new to you car, as it can have an effect on fe. I generally recommend replacement with a cheap eBay battery ground kit.
