Old 06-30-2011, 02:38 PM   #2 (permalink)
Daox
It will take some research and a fair amount of work, but it can probably be done. You need to tap into whatever passage is used to oil the transmission components and add an electric oil pump to keep oil going to the transmission bits. You'll also have to come up with some way of turning this pump on and off.
The Following User Says Thank You to Daox For This Useful Post:
katiep (07-01-2011)
