ok, so, back up a little bit. If you do not change the idle throttle position, but you increase the load on the alternator (so you can make hydrogen/o2 to inject downstream of the throttle), you should probably still see a drop in rpm.
I would probably get it running then disconnect the battery and then turn on the hho so you know you are not borrowing any battery power.
