Old 07-01-2011, 03:32 PM   #147 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by KamperBob View Post
Whilst playing with 1/4" pink-board I noticed the shinier side has a plastic film coating. I wonder it both sides react the same to polyester resin or how much difference that thin layer might make...
Unfortunately, that plastic coating has numerous holes spaced at regular intervals. At the least, polyester resin would seep through the holes and cause regular spaced gloppy holes in the 1/4 foam sheeting.
I am not sure if the Styropoxy would stick to that plastic. It should, if it's an epoxy-based coating. I'll find out once the Styropoxy comes in.
