Old 06-30-2011, 04:48 PM   #141 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I am just reposting a store I read about in another thread.
Raka, Inc. 772-489-4070
A three quart kit from these guys should do the trick for you.
This cloth from the overstock section would do nicely.
Style 7544- 10oz x 50"
That is 10oz per square yard, but $4.00 per running yard. Figure on 5 running yards outside and 7 inside. 12 yards at 10 OZ x 1.3 = 156 Oz or ~10 pounds.
3 qts resin = ~6.6 pounds (epoxies are around 1.1 specific gravity and close to 100% solids)
You could dance on it afterwords.
3 qt kit is $39 plus $48 in cloth and some tools, and shipping. It will run you a little over $100. You need to cover that epoxy with a UV barrier or it will eventually chalk up over time. You could pigment it, but I would still paint over it with some good paint.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
BamZipPow (06-30-2011), t vago (07-01-2011)
Old 06-30-2011, 06:25 PM   #142 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I used to use West system and the proset brands that gungeon brothers sold. I developed an allergy to it. In the last year I have been using US composites epoxy brand with excellent results and a somewhat lower price. I don't seem to react to the epoxy yet.
Please make some parts that are not structural and include overlap joints to test before you work on your nice shape. You will be glad that you did.
Noah Webster, 1787
The Following 3 Users Say Thank You to Varn For This Useful Post:
BamZipPow (06-30-2011), skyking (06-30-2011), t vago (06-30-2011)
Old 06-30-2011, 06:28 PM   #143 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Don't worry about me experimenting on my aerocap. I have (literally) a truck-bed full of scrap FoamulaR foam material to experiment with.
The Following User Says Thank You to t vago For This Useful Post:
Varn (06-30-2011)
Old 06-30-2011, 06:35 PM   #144 (permalink)
skyking's Avatar
My dad got sensitized to the West System epoxy back in the 80's. I had to finish his last boat for him. Of course things have changed, but I always use gloves.
2003 TDI Beetle
2002 TDI Beetle
Old 07-01-2011, 10:31 AM   #145 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Whilst playing with 1/4" pink-board I noticed the shinier side has a plastic film coating. I wonder it both sides react the same to polyester resin or how much difference that thin layer might make...
Recreation Engineer
Old 07-01-2011, 02:29 PM   #146 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
Perhaps a use could be made of shrink wrap material. There are many different types, some of which are used for semi-permanent outdoor storage of equipment.
The Following User Says Thank You to CFECO For This Useful Post:
t vago (07-01-2011)
Old 07-01-2011, 02:32 PM   #147 (permalink)
MPGuino Supporter
t vago's Avatar
Unfortunately, that plastic coating has numerous holes spaced at regular intervals. At the least, polyester resin would seep through the holes and cause regular spaced gloppy holes in the 1/4 foam sheeting.
I am not sure if the Styropoxy would stick to that plastic. It should, if it's an epoxy-based coating. I'll find out once the Styropoxy comes in.
Old 07-01-2011, 02:38 PM   #148 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
http://www.youtube.com/user/AmericanShrinkwrap
Old 07-01-2011, 04:10 PM   #149 (permalink)
Do more with less
You really don't need to worry about those holes or the peelable film. Just tack your cloth down and paint on the epoxy. If you end up with a strong enough part the foam can be dissolved out with gas or you can peel it off with a blade (hard way). If you only use one layer of cloth you won't have much structural integrity and will want to make sure that the foam stays in place.
How are you going to control warpage? Seams are where you are going to get most of it. When I made this type of contstruction I glued scraps of 1/4" pink board behind the seam and used the 2 part foam as glue. If it were mine, I would lay it up on the truck and use plastic sheeting to protect the finish and tires.
Noah Webster, 1787
Old 07-01-2011, 04:40 PM   #150 (permalink)
skyking's Avatar
I was thinking about that myself, a couple of layers to be sure.
2003 TDI Beetle
2002 TDI Beetle
aerocap, aerodynamic, aeroshell, dakota, truck
