Old 07-02-2011, 07:12 AM   #53 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by California98Civic View Post
The tape that I still have to use to seal the gaps and edges has damaged the paint job with sticky glue that I can't get off (yet). Bummer. Magnets hold it down via straps to the lid's underside. And I have tested the straps hold, but the tape seals gaps and smooths edges. I'm pausing this project until I'm better skilled in fabrication. I'll test the current build once I get the paint clean and devise a better way to seal gaps. Good luck with your efforts Brucepick. I'll be following. On to my airdam today after work and yard projects...
Honestly, I haven't done a lick of work towards a trunk lid spoiler, beyond tossing some cardboard cartons in the garage for possible mockups, and of course all the design contemplation in these threads. However, I've been doing some work on the belly pan and future flat wheel covers.
As for removing the tape ick, try some Goo Gone. Hardware store, maybe also in WalMart and Home Depot. A yellow/gold fluid in a tall flat clear bottle. Works very well, but TEST IT first on a hidden spot, maybe the hood underside. I have not had it destroy any finishes but it is strong stuff. I've also used charcoal lighter fluid to get that sort of mess off painted surfaces, very successfully.
Coast long and prosper.
