Originally Posted by Weather Spotter
What did you make the belly ban? I was thinking of using some scrap steel roofing sheets I had on hand.
I used foam and fiberglass, just like the tail extension.
You can see the build here....
http://ecomodder.com/forum/showthrea...lly-10638.html
My goal was to make light-weight panels, that are reasonably easy to remove if necessary.
The panels already consider oil drainage as well as oil filter replacement.
Jim.
