Old 07-02-2011, 06:19 PM   #250 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by KillerBeeZ View Post
I have a 2 year old so I didn't have time to read the entire thread...thus I don't know if these were brought up... but I have a warning.
Some cars in some situations need that air flow to cool off the brakes. I know my 03 Grand Caravan would get really hot if I did this as they get hot as it is and I drive mostly in the city. So be sure to check the brake temp because the hotter they get the less they work and they will need replacing a lot sooner.
If your brakes get hot with this mod, I'd suggest replacing the entire brake assembly with one that's more for racing as they are bigger, disperse heat better and generally are much better/safer anyway. If it still gets hot, you will need to reverse the mod a little by making a few vents in the covers.
While heat may not buildup...it might.
Here is a thread I started on cooling front brakes:
http://ecomodder.com/forum/showthrea...kes-18011.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
