Old 07-03-2011, 04:44 PM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Correct. If your alt has a field wire then putting it on a relay will allow you to manually (de)activate it. On the other hand, if your alternator's field is self-exciting, then it won't be easy. In that case you can either re-do the internal circuits (AXMonster tried, but didn't get it working, iirc), or you can try A/C clutch pulley, which I don't recall anyone actually doing.
There's quite a bit about alternator killing here, but you can start here and then search for more:
Deceleration Alternator
