Old 07-04-2011, 01:57 PM   #47 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by ShadeTreeMechanic
Why couldn't an ecomodder use sheet metal or aluminum instead of flammable coroplast? On my Maxima the exhaust system is insulated (but not the cats) so covering the entire exhaust system and cooling just the cat should in theory be acceptable. I'm also considering installing ground effects on the sides and fronts then putting the underpan at that level which would keep the metal away from the heat, and assuming I leave enough air flow into the engine compartment it should be kept cool if I make it airtight.
I am using 2 panels of 3x4 0.050" 5052 aluminum right now for a partial panel kit. It is rather heavy. Another portion is fiberglas reinforced vinyl, which is also heavy. My next kit will be from corroplast. Once I get done I'll post a pic or two.
What is your exhaust made of? SS? I was looking to do the same thing, at least after the converters. Insulation will help keep exhaust temps and velocities up.
Originally Posted by dmac257 View Post
Where did you go to get 4X8 coroplast. Local hardware store doesnt carry it so looking for other sources please??
Don
I did a Google search for 4x8 corroplast suppliers when I started looking. I found Regal Plastic in OKC Home, and Regal-Plastics in DFW. Regal-Plastics They also have other TX locations; I assume there's something near you...
mcrews; I bought some black plastic plant pots I intend to cut in half, and then glue/RTV the halves onto the bottom of the belly panels, in front of the wheels...for a fairing.
Last edited by ECONORAM; 07-04-2011 at 02:03 PM.. Reason: added tire fairing thought
