Old 06-02-2011, 10:44 PM   #41 (permalink)
nice. I like the aluminum crosspiece behind the rear tires - great way to brace that piece and I dont think i would have thought of it myself.
Old 06-09-2011, 01:03 AM   #42 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Here are pics of the front.
these are the ftont tire fairing.
passenger side.
I used the same angle bar for the back of the panel tp mount on
close up of fairing:
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-09-2011, 01:41 PM   #43 (permalink)
interesting. i would not have thought to angle the tire fairing inward like that.
i like the zipties. mine will have lots of zipties, and i will keep a pair of snips in the glovebox in case I need to remove it quickly...
Old 06-09-2011, 05:03 PM   #44 (permalink)
mcrews's Avatar
bill
thanks
theoriginal fairings are just directly above
theangle aluminuum is runningjust under thebottom
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-09-2011, 06:29 PM   #45 (permalink)
Getting lots of good ideas. Thank you for sharing.
Old 06-20-2011, 08:25 PM   #46 (permalink)
mcrews's Avatar
More pics on the front:
I only used 2 pieces of aluminuum angle. the center piece is there to anchor the one piece choroplast sheet from flapping
I cut the choroplast to fit all the way under the front lip.
I then used a flat piece of aluminuum and 4 sheet metal screws to anchor the center line to the aluminuum angle bar that runs down the middle
you can see the factory shields that sit in front of the tire. I made a set uot of choroplast and put them at the exact same angle.
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-04-2011, 01:57 PM   #47 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by ShadeTreeMechanic
Why couldn't an ecomodder use sheet metal or aluminum instead of flammable coroplast? On my Maxima the exhaust system is insulated (but not the cats) so covering the entire exhaust system and cooling just the cat should in theory be acceptable. I'm also considering installing ground effects on the sides and fronts then putting the underpan at that level which would keep the metal away from the heat, and assuming I leave enough air flow into the engine compartment it should be kept cool if I make it airtight.
I am using 2 panels of 3x4 0.050" 5052 aluminum right now for a partial panel kit. It is rather heavy. Another portion is fiberglas reinforced vinyl, which is also heavy. My next kit will be from corroplast. Once I get done I'll post a pic or two.
What is your exhaust made of? SS? I was looking to do the same thing, at least after the converters. Insulation will help keep exhaust temps and velocities up.
Originally Posted by dmac257 View Post
Where did you go to get 4X8 coroplast. Local hardware store doesnt carry it so looking for other sources please??
Don
I did a Google search for 4x8 corroplast suppliers when I started looking. I found Regal Plastic in OKC Home, and Regal-Plastics in DFW. Regal-Plastics They also have other TX locations; I assume there's something near you...
mcrews; I bought some black plastic plant pots I intend to cut in half, and then glue/RTV the halves onto the bottom of the belly panels, in front of the wheels...for a fairing.
Last edited by ECONORAM; 07-04-2011 at 02:03 PM.. Reason: added tire fairing thought
Old 07-04-2011, 03:56 PM   #48 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Most sign places will sell you 4'x8' coroplast...
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 02-14-2012, 02:25 PM   #49 (permalink)
Honda Civic - '91 Honda Civic DX
90 day: 40.65 mpg (US)
Looks good, your work is really good!
Old 02-25-2012, 07:30 PM   #50 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Undercover
Excellent work !
Mercedes 300 D turbo 1993
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
