Old 07-06-2011, 11:56 AM   #17 (permalink)
alexander.foti
Originally Posted by dcb View Post
Not sure there, if you left the timeout set to 7 minutes and it is resetting after 2 then it might be a power glitch. Double check your timeout setting in the setup.
It only does it when my kill switch is used, and only reset the current trip the tank info stays, very odd, will duoble check my timeout period.
