I tried using electric fuel pumps just to transfer the oil from one jug to another before putting it into my truck. One was a low pressure vibration lift pump suitable for supplying a diesel injector pump or carburetor, and the other two were intended for EFI and capable of higher pressure. All three could barely manage a trickle, and would overheat after a few minutes of struggling. My truck has a mechanical lift pump driven off the camshaft but I would imagine it would still have worked pretty hard pumping 100% WMO.
Like I said earlier, I'm no expert on the topic, but I imagine fuel heating would be required to thin the stuff out enough to pump it.
1986 F250 Diesel with 3.08 gears, E4OD, turbo
1996 Saturn SL1 EV, 32KWH lithium (LiFePO4) battery
