Old 07-11-2011, 10:14 PM   #112 (permalink)
user removed
The B29s had terrible problems with the same engine. FI solved the problem. If you gave a 29 full throttle at sea level and lower altitudes it could blow the cylinder heads right off the engine, not a situation you wanted with ten tons of explosives in the bomb bay.
regards
Mech
