Old 07-12-2011, 01:22 PM   #722 (permalink)
eimix
Originally Posted by dewasha View Post
you know if they can communicate with the ABS?
No ABS or other connection (Airbags, windows, radios, transmition or other)
Only main ECU, (0x33 channel).
Others should work too with same hardware, but no tests or software development is done.
If you need such functionality - you should use normal OBD2 cable for your car and PC software for this purpose.
K line is used only, L line is not needed any more. If K line does not work for you - u should read all this thread and google for using L line.
The Following User Says Thank You to eimix For This Useful Post:
dewasha (07-12-2011)
