I should note that mine is not exactly the same dimensions as MetroMPGs - but I used his measurements to get the angle right. He had suggested I shorten mine to improve view. Because I figured the window would solve the problem I actually lengthened mine a bit so it extends a few inches past the bumper (as you can see in the final pic). Also in comparing it now I see I didn't go all the way down to the tail-lights with the side pieces. I had intended on it I just forgot when I cut the side-pieces out
![Embarrassment](/forum/images/smilies/redface.gif)
. I think I'll probably put on some extensions to go all the way to the tail-lights because it seems like it would be worth it. and not too hard
