Old 07-13-2011, 08:31 AM   #725 (permalink)
eimix
Originally Posted by Bix View Post
The Si9243 has a pin for the L-line. Would I be right in assuming the chip would not function correctly without the L-line?
http://datasheet.octopart.com/SI9243...heet-34131.pdf
full chip description. L line is connected to RXL in schematics.
But L line communication is not uses in OBDuino (there was attempt to do this, but not used any more)
As well in
http://ecomodder.com/forum/showthrea...tml#post244429
(checked and working configuration) RXL line is not connected.
The Following User Says Thank You to eimix For This Useful Post:
Bix (07-13-2011)
