Originally Posted by BamZipPow
Since you have the tailgate down as the bottom layer of the tail cone...you can put in a rear window on the tail cone fer better rear vision!
Looks good. How do you store it?
I guess you could test some clear covers that extend from the tail lights to the end of the tail cone.
An Aerolid does need help on rearward visibility, that would be a great way to gain some.
The tailcone fits nicely inside the truck bed when not in use. basjoos had this idea figured out over two years ago. He has forgotten more than I will ever know about aerodynamics. His post is the fifth one at the link below.
While at this link, check out round.boaters up to date fuel log. He is getting much better than a 4% increase in fuel efficiency.
http://ecomodder.com/forum/showthrea...olid-8444.html
Bondo
