Old 07-15-2011, 08:39 PM   #81 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by dcb View Post
If you are trying to imply that a 7hp series generator can replace a 25hp engine, you have some explaining to do.
Heck, it's easy to do! All you need is the generator, filter its output into some HHO cells to generate some Brown's Gas, feed the output into a normal engine with one of them Tornado thingies in the intake (be sure to flow the gasoline powering the generator through two of them Fuel Saver magnets first), swap out the engine and generator oil with some of that Teflon-enhanced oil additive, gut the catalytic converter because it blocks exhaust flow, install spark gaps on the ignition systems of the generator and engine, and top the car off with one of them Ram Implosion wings!
