Old 07-15-2011, 10:02 PM   #82 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
t_vago that is a HUGELY inefficient way to use the generators output.
it would be far far far more efficient to ditch the gas motor and use an electric motor run off the genny. 4 times more efficient at least. ie you need 4 times more generator power to get the same thing via HHO.
the trick with using a generator as I see it IE a generator one of us mere mortals can afford is going to be "ACCELERATION"
cruising and charging is no problem as I see it but that genny can not produce the 400 amps minimum your going to need to accelerate from a STOP.
so some sort of batter pack hybrid drive type deal is going to be needed. use the battery and genny power to accelerate from a stop and once at cruising use excess power to replenish the battery for the next acceleration.
I can not afford to even attempt such a project and it would still require a rather large generator. I don't think my 4500 watt unit would cut it even if I could afford the electric controller and motor.
