Thread: MPG? Who cares!
Old 07-19-2011, 01:18 AM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I've looked into ultralights plenty. 255lbs powered is hard to do anything really aero, mostly just hang glider style or parachute style. I suppose someone could do a balsa and monocote thing, but it comes up against a 55mph limit and 25mph stall speed then. Lots of room for aerodynamic improvement though.
this is pretty much at the limits of what you can do within the constraints
http://www.interplaneaircraft.com/zjpicsvideos.htm
here is a page All About Ultralights - FAQs on getting started flying an ultralight aircraft.
1. What is an Ultralight Aircraft?
Ultralights are defined and operate under simple guidelines specified in FAR Part 103. A summary of the rule is provided here:
Single occupant only for recreation or sport purposes with 5 gallons maximum fuel.
Unpowered free flight empty weight under 155 pounds or powered weighs under 254 excluding floats or safety devices.
55 knots maximum calibrated airspeed at full power in level flight, power-off maximum stall speed 24 knots calibrated.
Can be inspected by FAA to make sure it meets criteria as an ultralight.
Vehicle not required to meet any airworthiness certification standards
Pilot not required to meet any aeronautical knowledge, age, or experience requirements to operate or to have airman or medical certificates.
Not required to be registered or to bear markings of any type.
No operation is allowed that creates a hazard to other persons or property.
Only operate between sunrise and sunset unless equipped with a suitable anti collision light extending flight time to twilight periods 30 minutes before sunrise and 30 minutes after sunset.
Yield the right-of-way to all aircraft and not create a collision hazard with any aircraft.
Do not operate an over any congested area of a city, town, or settlement, or over any open air assembly of persons.
All operations are conducted in uncontrolled airspace unless prior authorization from the ATC facility to operate in within Class A, Class B, Class C, or Class D airspace, or within the lateral boundaries of the surface area of Class E airspace designated for an airport.
Must comply with flight restrictions in the proximity of certain areas designated by Notice to Airmen (NOTAM) and Temporary Flight Restrictions (TRF).
No person may operate an ultralight vehicle except by visual reference with the surface.
Visibility and cloud clearances similar to general aviation airspace. (see www.asa2fly.com for the specific FAR 103)
